1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASL attributes of Motor Record fields
To: Ronald Sluiter <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Fri, 06 Apr 2007 17:10:18 -0700
Hi Ron, I've changed the ASL attributes in the motor record's DBD file here
at SLAC to meet our immediate needs for the LCLS.  This seems like a
reasonable set of fields to be at security level 0.
I've included the file so you can review it, and possibly use it to make up
the official version.
Best regards,
-doug
Doug Murray
Stanford Linear Accelerator Center
LCLS Controls Department
2575 Sand Hill Road
Menlo Park, CA 94025 MS-102
On 3/30/07 11:42 AM, "Ronald L. Sluiter" <[email protected]> had this to
say:
> Hello Doug,
> Sorry for the delayed response; I've been out of the office the
> past few days.
> I've looked into this as far as finding ancient references (01/04/2000)
> to access security changes I made to the motorRecord.dbd file here,
> http://www.aps.anl.gov/upd/people/sluiter/epics/motor/R4-1/motor_release.html
> I don't understand why I made these changes. I'll have to look
> into this further and get back to you.
> Best regards,
> Ron
> Doug Murray wrote:
>> Hi Ron
>> I was looking at the security levels associated with the fields of the
>> motor record (version 5.9 and 6.0) DBD file. The ASL settings for
>> these fields don¹t seem right.
>> In those files, the level for the standard Motion fields, VAL, VELO
>> and so forth are the default, ASL1, while the calibration related
>> fields like SSET, SUSE, MRES, etc. are set to ASL0.
>> These seem backwards to me. Am I misunderstanding the way that access
>> security is intended to be implemented for the motor records? I would
>> expect that the commonly used fields (for general use) should be ASL0,
>> and the ?calibration¹ fields should be only available at ASL1, which
>> also implies access to level 0.
>> Best regards,
>> -doug
Attachment: motorRecord.dbd
Description: application/applefile
Description: Binary data
Prev: RE: Frame grabber Elder Matias
Next: First photo-electron beam produced by the LCLS injector Shoaee, Hamid
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
