1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Frame grabber
From: "Pearson, MR \(Matthew\)" <[email protected]>
To: "Emmanuel Mayssat" <[email protected]>, "EPICS Tech-Talk" <[email protected]>
Cc: <[email protected]>
Date: Tue, 10 Apr 2007 13:48:23 +0100
We've been using, as well as the Flea cameras, the AVT (Allied Vision
Tech) Oscar Firewire cameras, which are high resolution and have colour
versions. We've only run this in Windows though, using the CMU driver.
Would be interesting to see if this works in Linux with Coriander...
We've also tested the JAI TMC-1405 Gigabit Ethernet camera, which is a
1.4Mpixel colour camera with an ethernet connection (no encoding or
compression though) - this isn't as sensitive as the Flea cameras. This
doesn't have a web server, and needs windows software to view the video.
There are software projects out there which can capture IP video, but
not sure what Linux support exists.
Axis now produce a high resolution network camera (the 223M). This might
be a good solution for diagnostics. But it's probably not as sensitive,
or have the same bandwidth, as cameras such as the Fleas or AVTs etc.
Probably not suitable for low light diagnostics. But this is like all
the other Axis cameras, with built in web server, compression, encoding,
etc.
Cheers,
Matthew
Diamond Light Source
-----Original Message-----
Sent: 05 April 2007 19:05
To: EPICS Tech-Talk
Cc: [email protected]
Subject: Frame grabber
Hello,
I am using EPICS on a linux IOC.
I am interested in doing some video acquisition.
I was wondering if anybody has already developed a video epics driver.
If so, what is the hardware/software combination you recommend?
I am looking at all possible solutions, i.e. snapshot mode or 30Hz+ real
time acquisition.
Alternatively, I may be interested in all in-one-device (camera for
acquisition + web server and Ethernet connection device)
At this point anything goes ;-)
Emmanuel
Re: Frame grabber Wesley Moore
RE: Frame grabber and image analysis Emmanuel Mayssat
Frame grabber Emmanuel Mayssat
Prev: Re: epics compiling problem ʦê»Àñ
Next: Re: Frame grabber Wesley Moore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Frame grabber Russ Berg
