1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS thread problem on cygwin-x86
Cc: [email protected]
Date: Fri, 27 Apr 2007 13:16:23 -0500
1) Does putting the epicsThreadSleep(.001); into the thread wrapper function that actually invokes the EPICS thread fix things?
2) Have you tried running this under gdb to see where the crash occurs?
On Apr 27, 2007, at 1:01 PM, Mark Rivers wrote:
Folks,
I have found a problem with EPICS threads on cygwin-x86. The problem
showed up when doing the command "asynReport" with the "details"
argument=0 (default). The IOC crashes when this is done. It is a timing
problem with the thread that asynReport creates.
I have come up with a very simple test program to demonstrate the
problem:
#include <epicsEvent.h>
#include <epicsThread.h>
#include <epicsExport.h>
#include <iocsh.h>
typedef struct myArgs {
    epicsEventId done;
    int  delay;
} myArgs;
static void myThread(myArgs *pArgs)
    if (pArgs->delay) epicsThreadSleep(.001);
    epicsEventSignal(pArgs->done);
static void threadTest(int delay)
    myArgs args;
    epicsEventId done = epicsEventMustCreate(epicsEventEmpty);
    args.delay = delay;
    args.done = done;
    epicsThreadCreate("myThread",
          epicsThreadPriorityLow,
          epicsThreadGetStackSize(epicsThreadStackSmall),
          (EPICSTHREADFUNC)myThread, &args);
    epicsEventMustWait(done);
    epicsEventDestroy(done);
/* iocsh functions */
static const iocshArg threadArg0 = {"Delay",       iocshArgInt};
static const iocshArg * const threadArgs[1] = {&threadArg0};
static const iocshFuncDef threadTestFuncDef= {"threadTest", 1,
threadArgs};
static void threadTestCallFunc(const iocshArgBuf *args)
    threadTest(args[0].ival);
static void threadTestRegister(void)
    iocshRegister(&threadTestFuncDef, threadTestCallFunc);
epicsExportRegistrar(threadTestRegister);
The function threadTest() simply creates a thread, and then waits for it
to complete with epicsEventMustWait().
If the delay argument is non-zero the thread sleeps for 0.001 second.
It then signals the event and returns.
On Linux this program works fine.
However, on Cygwin it crashes if delay is 0, i.e. if it does not sleep
for .001 second.
$ ../../bin/cygwin-x86/threadTest.exe st.cmd
#!../../bin/linux-x86/example
## You may have to change example to something else
## everywhere it appears in this file
#< envPaths
dbLoadDatabase("../../dbd/threadTest.dbd",0,0)
threadTest_registerRecordDeviceDriver(pdbbase)
iocInit()
Starting iocInit
### EPICS IOC CORE built on Aug 25 2006
### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
iocInit: All initialization complete
epics> threadTest 1
epics> threadTest 0
pthread_create error Resource temporarily unavailable
Segmentation fault (core dumped)
This is a serious problem, since any thread that returns too quickly
causes a crash on Cygwin.
Can someone who knows about EPICS threads figure out why this is
crashing, and how to fix it?
<threadTest.c>
<threadTestInclude.dbd>
<threadTestMain.cpp>
<Makefile>
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
RE: EPICS thread problem on cygwin-x86 Mark Rivers
Prev: EPICS thread problem on cygwin-x86 Mark Rivers
Next: [Fwd: New for Argonne National Laboratory Employees - Your Quarterly Newsletter from National Instruments] Ned D. Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EPICS thread problem on cygwin-x86 Mark Rivers
