1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: wxPython timer and KEK CaPython314 cause core dump
To: Noboru Yamamoto <[email protected]>
Cc: [email protected]
Date: Tue, 1 May 2007 14:42:18 -0500 (CDT)
Hi Noboru,
Thank you for the update.  I found that the new version did
not solve my problem.  I am running on an Intel duo core.
Anything special I need to do?  Please test the following
code.  All lines are necessary to reproduce the crash.  One
important observation is that the smaller the milliseconds,
the sooner the crash happens.  Try 1 or 0.1; it crashes almost
immediately.  Thank you for your help.
Zhong
# Segmentation fault (core dumped) occurs after
# running a while.
import wx
import ca
def onTimer(event): pass
print ca.__version__
ca.Monitor('S:SRcurrentAI') # Supply a PV here.
appli = wx.PySimpleApp()
frame = wx.Frame(None)
timer = wx.Timer()
timer.Bind(wx.EVT_TIMER, onTimer)
timer.Start(milliseconds = 10, oneShot = False)
appli.MainLoop()
Other info:
 Pyhton 2.5
 wxPython 2.6.3.3
 RedHat Linux x86_64
 GCC 4.1.1
---- Original message ----
>Date: Thu, 26 Apr 2007 14:29:00 +0900
>From: Noboru Yamamoto <[email protected]>
>To: [email protected]
>Hi,
>I have updated my version of CA-Python interface module.
>Please find a new tar.gz file as an attachment to this e-mail.
>It may have multi core CPU(such as Intel Core Duo on my MacBook).
>As far as I tested, it runs stable on a single core
processors, i686 and
>PPC.
>Best regards,
>Noboru
>Zhong Ren wrote:
>> Dear Noboru,
>> Thank you.  I must say the KEK CaPython314 is very easy to use.
>> I am not surprised that your little test below won't crash,
>> since it does not contain a wx.Timer.  In order to repeat my
>> crash, a wx.Timer must be constructed, it must be bound to a
>> onTimer function, and it must be started.  Using
>> threading.Timer instead of wx.Timer will not cause the crash.
>>  I cannot tell who is guilty, wx.Timer or CaPython314.  I also
>> have the feeling that Python 2.5 may be the problem.
>> Zhong
>>> Date: Wed, 06 Dec 2006 10:47:29 +0900
dump
>>> Hi,
>>> I'm not familiar with WxPytho (yet).
>>> But, the following code works on MacBook running MacOSX
>> 10.4.8 with
>>> Python2.5,
>> wxPython2.7-osx-unicode-2.7.2.0-universal10.4-py2.5.dmg
>>> and KEK version of CaPython314 ( I should have used the
>> different name
>>> to avoid confusion with FNAL version. Sorry).
>>> import wx,ca
>>> class MyApp(wx.PySimpleApp):
>>>    def OnInit(self):
>>>        frame = wx.Frame(None, -1, "Hello from wxPython")
>>>        frame.Show(True)
>>>        self.frame=frame
>>>        self.ch=ca.channel("fred")
>>>        self.ch.wait_conn()
>>>        self.ch.monitor(self.ca_callback)
>>>        self.ch.flush()
>>>        self.SetTopWindow(frame)
>>>        return True
>>>    def ca_callback(self,valstat):
>>>        self.ch.update_val(valstat)
>>>        self.frame.Title="%s:%f"%(self.ch.name,self.ch.val)
>>> if __name__ == "__main__":
>>>    app = MyApp(0)
>>>    app.MainLoop()
>>> I hope this can give some idea.
>>> Regards,
>>> Noboru Yamamoto
>>> EPICS group/J-PARC control group
>>> KEK, JAPAN
>>> Zhong Ren wrote:
>>>> I managed to isolate a core dump in a minimized Python code
>>>> (see below).  I found two components are essential to cause a
>>>> core dump: wx.Timer and ca.Monitor (or ca.Get).  Can someone
>>>> tell what the problem is?
>>>> import wx
>>>> import ca
>>>> timer = wx.Timer()
>>>> appli.MainLoop()
>>>> Other info:
>>>> Pyhton 2.5
>>>> wxPython 2.6.3.3
>>>> RedHat Linux x86_64
>>>> GCC 4.1.1
>>>> To test, let the routine run for a while.  A core dump will
>>>> occur in a few minutes.
>>> ________________
>________________
>CaPython-1.7.tar.gz (40k bytes)
>________________
>noboru.yamamoto.vcf (1k bytes)
Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Prev: MV1200/dec211x40 end driver auto negotiation bug, Thompson, David H.
Next: Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
