1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Crashing ioc @IPNS
To: "Walsh, Thomas R." <[email protected]>
Cc: [email protected]
Date: Mon, 07 May 2007 10:32:59 -0500
Hi Tom,
Walsh, Thomas R. wrote:
We have a VME ioc that crashes intermittently. We are running 3.13.7 and using a MVME 172-353 processor. We have several display meters that feed serial data into the ioc by way of the TIP866 serial module and I believe one the serial connections may be the culprit. Is there any type of error record in epics or Vx Works that we can look at that might give us a clue on why this happening.
We would need to know what kind of serial device support you are using to be able to help with that - MPF, devAscii/drvSerial etc.
Is there a good place to get information on VX Works commands other than WR. I have tried to use checkStack and printErrno 0 with no success.
Which version of vxWorks/Tornado? If you have any printed manuals then there is a chapter of the VxWorks Programmers Guide called Target Shell which also references the Tornado User's Guide chapter on the Tornado Shell (which you are most likely not using but which covers some of the commands available in the target shell). From Tornado 2.x these printed manuals are also provided in HTML format in the tornado installation tree under docs.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
Crashing ioc @IPNS Walsh, Thomas R.
Prev: Crashing ioc @IPNS Walsh, Thomas R.
Next: INSTALLING IOC Applications Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
