1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CAJ usage
To: <[email protected]>
Date: Tue, 08 May 2007 14:40:33 -0500
Well, getting closer.
I had jca-2.3.1 source downloaded earlier.
Moved to directory and did 'ant', it said:
build.core.java:
     [echo] Building core classes
    [javac] Compiling 67 source files to
/usr/local/EPICS/modules/soft/jca/jca-2.3.1/O.core
    [javac]
/usr/local/EPICS/modules/soft/jca/jca-2.3.1/src/core/gov/aps/jca/dbr/DBR_Double.java:89:
cannot resolve symbol
    [javac] symbol  : method format
(java.util.Locale,java.lang.String,java.lang.Object[])
    [javac] location: class java.lang.String
    [javac]                             toValue[i] =
String.format(Locale.US, formatFString, params);
    [javac]
    [javac]
/usr/local/EPICS/modules/soft/jca/jca-2.3.1/src/core/gov/aps/jca/dbr/DBR_Double.java:93:
String.format(Locale.US, formatEString, params);
    [javac]
    [javac]
/usr/local/EPICS/modules/soft/jca/jca-2.3.1/src/core/gov/aps/jca/dbr/DBR_Float.java:91:
    [javac]
    [javac]
/usr/local/EPICS/modules/soft/jca/jca-2.3.1/src/core/gov/aps/jca/dbr/DBR_Float.java:95:
    [javac]
    [javac]
/usr/local/EPICS/modules/soft/jca/jca-2.3.1/src/core/gov/aps/jca/jni/JNIContext.java:147:
    [javac] symbol  : constructor IllegalStateException
(java.lang.String,java.lang.Throwable)
    [javac] location: class java.lang.IllegalStateException
    [javac]       throw new IllegalStateException( "Context not
initialized", th );
    [javac]             ^
    [javac] 5 errors
BUILD FAILED
/usr/local/EPICS/modules/soft/jca/jca-2.3.1/build.xml:144: Compile
failed; see the compiler error output for details.
Total time: 5 seconds
Getting closer, I would say.
So, you're saying that caj only replaces the JNI part of jca with a
java package, instead of the native interface package?
David
>>> Kay-Uwe Kasemir <[email protected]> 5/8/2007 2:24 PM >>>
Hi:
You need jca, which gives you
a) The basic java API, a lot of interfaces, in a jca.jar file.
    That's what ant complains about with the missing gov.aps.jca.
b) A JNI implementation of those interfaces,
    using the CA client lib from EPICS base,
    in some *so or *dll file.
Just jca works fine, but the problem is that it depends on the
JNI implementation, i.e. binary, system-dependent code.
You need to build the JNI part of jca for Win32, Linux, Linux 64-bit,
OSX-on-ppc, OSX-on-intel, for every version of EPICS base that
you want to use.
CAJ provides a pure java implementation, so it replaces (b).
At the SNS, we had some problems with CAJ possibly causing
hangups of CA server threads on IOCs, but the current hope is
that that's been fixed as long as you use the latest jca/caj
and IOCs run R3.14.9.
-Kay
On May 8, 2007, at 15:04 , David Dudley wrote:
> I'm trying to configure and use the CAJ library, since I can't be
sure
> what kind of machine the application will be used on.  It can
> almost be
> guaranteed that whatever machine it is, it won't have EPICS on it,
for
> sure.
> I downloaded caj-1.1.3-src and caj-1.1.3.tar, and am attempting to
> figure out how to use it.
> From the caj-1.1.3 source directory, I can't get ant to operate
> without
> giving pages and pages of errors.  It looks for package
'gov.aps.jca',
> but shows that package does not exist.
> Still working on getting use to java, I've been a 'c' programmer for
> around 20 years or so.
> All I did was go go to the source directory and type 'ant'.  Was
there
> something else I was supposed to do as well?
> David
>>>> "Matej Sekoranja" <[email protected]> 11/26/2006 1:49 PM
> Hi,
> sorry for the late reply.
>> Is there any additional information on utilizing the Jca library
> other
>> than the Tutorial listed?  I'd like to use a 'monitor' function to
> display
>> changing data, but there isn't exactly any documentation on it.
> There is a series of  EPICS training material.
> Java and JCA can be found here:
> http://www.aps.anl.gov/aod/bcda/epicsgettingstarted/developtools/
> java.html
> See also CA client library tutorials.
> Any help would be appreciated.
> The best thing is to look at BasicExample source (found in the
> sources). I
> attach it anyway.
> Matej
> <David Dudley.vcf>
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: CAJ usage J. Lewis Muir
Re: CAJ usage David Dudley
Re: CAJ usage Kay-Uwe Kasemir
Prev: Re: CAJ usage J. Lewis Muir
Next: Re: CAJ usage J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CAJ usage Kay-Uwe Kasemir
