1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: WebCA compiling issues
To: [email protected]
Date: Thu, 10 May 2007 10:05:48 -0400
When trying to make WebCA-1.0.0 in Cygwin, I get numerous error (all
involving functions beginning with "_NPN"). Here is an example:
plugin.o:plugin.cpp:(.text+0x365): undefined reference to
'_NPN_GetStringIdentified'
All of these errors occur following this command:
g++ -o libnpca.so -L/epics/base-3.14.9/lib/cygwin-x86/
-Wl,-rpath,/epics/base-3.14.9/lib/cygwin-x86/ npcashell.o plugin.o
repeater.o -lca -lCom -lpthread -lm -lgcc
I suspect that something isn't being linked correctly, specifically a
part of the gecko-sdk. However, I am not sure.
Has anyone else had this problem or found a solution?
Thank you for your help,
Doug Sheffer
Prev: Re: CAJ usage David Dudley
Next: Difficulty with building Channel Archiver Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CAJ usage J. Lewis Muir
