1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Difficulty with building Channel Archiver
To: tech talk <[email protected]>
Date: Fri, 11 May 2007 09:06:12 -0400
On May 10, 2007, at 18:46 , Szalata, Zenon M. wrote:
undefined reference to `curl_multi_strerror'
Hi:
Are you using the xmlrpc, xerces, w3c-libwww, ... libraries that come in the
ThirdParty subdir of the archiver sources, or versions that happened
to come with your linux distro?
I can't find any reference to the curl library inside the archiver sources themselves
nor those ThirdParty sources, so my first guess would be that you
end up using some other version of those libraries,
one that happens to depend on libcurl, and thus you'll have to add the
-Lpath and the -lcurl to the linker options.
-Kay
problem using streams with asyn for Agilent E5810A Ethernet->GPIB Matthew Pearson
Difficulty with building Channel Archiver Szalata, Zenon M.
Prev: Difficulty with building Channel Archiver Szalata, Zenon M.
Next: JCA Library usage David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Matthew Pearson
