1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB
To: tech talk <[email protected]>
Cc: "Rodney R. Porter" <[email protected]>, [email protected]
Date: Mon, 14 May 2007 08:32:19 -0500
FWIW, I use the following sscanf format for reading IDN strings: %39 [^\r\n]
This shares the advantage of %39c in that it will not overflow an EPICS string variable and also trims any trailing linefeed or carriage return characters -- useful for GPIB devices which use the EOI line to mark the end of a message.
On May 14, 2007, at 6:30 AM, Dirk Zimoch wrote:
The %c and %s input formats work like in scanf (the implementation actually use sscanf). Thus, %s stops reading at the first whitespace. This is probably not what you want. %39c only stops reading after 39 characters or at end of string. For more information see the manual pages for scanf.
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Rodney R. Porter
Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Dirk Zimoch
Prev: Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Dirk Zimoch
Next: RE: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Denison, PN (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
