> From: Dirk Zimoch [mailto:[email protected]]
> it seems I misunderstood what the current problem was.
> Indeed, stream first tries to read 1 byte with a quite long
> timeout (reply timeout) and then the rest with shorter timeout
> (read timeout). Also any very long message may be read in
> pieces from the underlying asyn driver.
> Even though this should be legal according to the asyn
> documentation (and works perfectly for serial and TCP), the
> GPIB driver did not support it, returned "asynOverflow" and
> destroyed the message. I had modified StreamDevice some time
> ago not to read a single byte at the beginning any more if he
> device is GPIB.
> But still there might be a problem with very long messages.
> As far as I know, the lastest version of asyn also fixes this
> problem and the GPIB driver does not return "asynOverflow" any
> more.
> Thus, either upgrading asyn or stream (or both) to the the
> latest version should fix your problem. Please report if that
> worked.
> Yours,
> Dirk
Using streamDevice CVS snapshot 20070511 works with both asyn 4-6 and
asyn 4-8. We didn't test the original stream device (2-1+all patches)
with the new (4-8) asyn, but I guess that doesn't matter. Many thanks
Peter Denison, Senior Software Engineer
Diamond Light Source Ltd., Diamond House, Chilton, Didcot, Oxon
OX11 0DE Tel: +44 1235 778511
- Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Dirk Zimoch
RE: waveform problem with asyn 4-8 Mark Rivers
CAJ Options David Dudley
<2007>
2025
2026
JCA Library usage David Dudley
<2007>
2025
2026
