1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn Delay
To: Robert Emery <[email protected]>
Cc: [email protected]
Date: Wed, 16 May 2007 16:04:44 -1000
Robert Emery wrote:
At 1 sec., the FLNKd chain of 12 "read" records (each record has to wait about 50 msec for a response) can not finish before the first one starts the chain again. From the messages that come out it looks like the message queue is backing up which causes delays for my "set" messages and causes my "read" messages to also be delayed and out of sequence.
Unless I can set up more than one port for this device I will have to live with the >1 sec read rate?
Rob,
even if you may be able to speed up the network response and/or your
CPU, at some point you'll run into a hardware limit. Those of us
who sometimes deal with Lakeshore 208 temperature scanners can tell you
that if you don't give the instrument it's settling time you get
what it will give you before it settles. In case of the LS208 that's
a "---" (which is also what it displays on its fron panel at that time).
Other devices may not respond in time our you get collisions on the
line (seen that one on an Edwards AGC).
Difference device(s), but been there, done that.
Sorry,
Maren
Asyn Delay Robert Emery
RE: Asyn Delay Mark Rivers
Re: Asyn Delay Robert Emery
Prev: RE: Asyn Delay Mark Rivers
Next: Honeywell S9000 driver Choate, William
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: waveform problem with asyn 4-8 Pedersen, UK (Ulrik)
