1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Howto set or read one value of a waveform record
To: Touchard Dominique <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 24 May 2007 15:52:51 -0500
Touchard Dominique wrote:
I am quiet beginner on Epics and I have started to try to use waveform
records (specialy Asyn/modbustcp waveform records)
I didn't find howto set or read just one value (per example the second)
on a waveform record.
May somebody advise me or point out a technical document which explain
howto do this ?
Thank's for your help.
Dominique Touchard.
You can read just one element with the subarray record (see http://www.aps.anl.gov/epics/wiki/index.php/RRM_3-13_SubArray) I don't know if the subarray record can set a single element of an array, but I don't think so.
You can do both with the aCalcout (array calc out) record, but note
that this record is not in base; it's an add-on, supplied by the calc
module.
(See http://www.aps.anl.gov/aod/bcda/synApps/calc/R2-6-3/aCalcoutRecord.html)
The doc describes how to access a single element, but it doesn't
mention setting an element.  I'll describe both, after some background:
The aCalcout record has scalar input fields A, B, C..., array input
fields AA, BB, ..., and an array output field AVAL.
Let's assume the AA field has the value[0,1,2,3,...]
You can select the 4th element with the following calc expression:
    aa[3,3]
(Numbering starts at zero.)  This will actually return the result
    [3,0,0,0,0,...]
You can get a subarray in its original place with the following expression:
    aa{3,5}
(-1 means the last element.)  This will return the result
    [0,0,0,3,4,5,0,0,...]
Armed with this, and with the ARR() command (arr(6) = [6,6,6,6....]), you
can set element 'a' of the array 'aa' to the value of 'b' with the following
expression:
aa[0,a-1] + aa{a+1,-1} + (arr(b)[0,0]>>a)
If aa = [0,1,2,3,4,...], a = 3, and b = 20, the first term yields
    [0,1,2,0,0,0...]
The second term yields
    [0,0,0,0,4,5,...]
The third term yields
    [0,0,0,20,0,0,...]
and the sum is
    [0,1,2,20,4,5,...]
Note that this is not an efficient way to do the job.  It's good
for unanticipated needs, because you can program it at run time, but
if I were planning to do this routinely, I would write a custom routine
for the genSub record.
(See http://www.observatorysciences.co.uk/images/genSubManual.pdf)
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Prev: Fedora 6 kernel-xen-2.6.20-1.2948 bug + NTFS mounting + openmotif Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Next: I need driver of vme-gpib for vxworks5.4 xuglei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
