1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: seqAuxThread: pvSysCreate() ca failure:
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Mon, 04 Jun 2007 17:03:09 -0500
Emmanuel Mayssat wrote:
After looking at the source, I found out that a typo appeared in my
seq/configure/RELEASE. Specifically for the options:
PVCA = TRUE
PVFILE = FALSE
PVTKL = FALSE
By the way, what are those options used for ?
i.e What is the use of PVFILE ? and PVTKL ?
The sequencer has a plug-in architecture for PV connections, conceptually very similar to EDM's PV plug-ins if you're familiar with that. The PVTKL variable (which should actually be spelled PVKTL) controls whether to build the Kettle interface plug-in that the W.M. Keck Telescopes (still/used to?) use in their control system. PVFILE is for a demonstration plug-in that William Lupton created that communicates over a file system; I know nothing more about it than that.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
seqAuxThread: pvSysCreate() ca failure: Emmanuel Mayssat
Re: seqAuxThread: pvSysCreate() ca failure: Emmanuel Mayssat
Prev: Re: Ocean Optics Spectrometer Elder Matias
Next: Mecartex positioner Shepherd, EL (Emma)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: seqAuxThread: pvSysCreate() ca failure: Emmanuel Mayssat
