1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problems in running application(ASYN)
To: zhangdemin99 <[email protected]>
Date: Wed, 6 Jun 2007 09:10:29 -0500
Make sure that the account running the EPICS/ASYN application has read/write privileges to the special file.
chmod 666 /dev/ttyS0
Or, if you want to restrict the access to a particular account:
	chown zhangdemin99 /dev/ttyS0
	chmod 600 /dev/ttyS0
Also, are you sure that you have the serial port name right in your startup command (st.cmd) file? Your message shows a backslash at the beginning of the name -- is this just a typo when you created the posting to tech-talk?
On Jun 5, 2007, at 9:18 PM, zhangdemin99 wrote:
Dear all,
I have built ASYN on my computer, but there are some problems when running application. It said: \dev/ttyS0 can't open Permission denied
Should I open the serial port in the Linux first or is there another problems? what should I do next?
many thanks in advance.
demin zhang
一 起 来,150 万 人 同 时 在 玩 的 梦 幻 西 游
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
problems in running application(ASYN) zhangdemin99
Prev: Re: problems in running application(ASYN) J. Lewis Muir
Next: RTEMS uC5282 with included tarball Phillip Sorensen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
