Andrew Johnson wrote:
Hi Till,
Till Straumann wrote:
I found the following problem (tested on
linux, solaris, base-3.14.9, base-3.14.8.2)
with the CA client on unix:
Partly confirmed on linux-x86 (Fedora-5) against R3.14.9 as follows:
uranus% cau
cau: get no_PV
**** The executable "caRepeater" couldn't be located
**** because of errno = "No such file or directory".
**** You may need to modify your PATH environment variable.
**** Unable to start "CA Repeater" process.
error on search for no_PV
couldn't open no_PV
cau:
While cau is still running, a ps from another terminal gives this:
uranus% ps -ef | grep cau
anj 1440 2430 0 09:45 pts/7 00:00:00 cau
anj 1444 1440 0 09:45 pts/7 00:00:00 [cau] <defunct>
anj 1446 2428 0 09:45 pts/6 00:00:00 grep cau
In my case though, the <defunct> process' parent is still the original
cau thread, and when the parent exits so does the defunct thread.
I'm not familiar with the internals of cau. However, note that the bug I
reported bites only if
a thread with an associated exit handler that synchronizes with the
tread's termination
(the 'errlog' thread is an example for such a thread) is already running
prior to
the attempt to spawn the caRepeater. Therefore the sequence
errlogInit(0) // creates errlog thread *prior* to attempt to spawn
caRepeater
epicsThreadSleep(0.5) // gives errlog thread time to register its
epicsAtExit handler
prior to the first CA activity is essential.
The problem occurs because the
1 forked process doesn't inherit threads
2 execle("caRepeater") fails, the spawning wrapper then calls 'exit()'
3 the epicsAtExit handlers are executed
4 the errlog thread's exit handler blocks for the errlog thread
to terminate and
*** hangs forever *** because there is no errlog thread in the forked
process (see 1)
Any long-running CA client application should be usable to prove this.
In libCom/osi/os/posix we can fix the problem using Till's fix of
having osiSpawnDetachedProcess() call _exit() which is a Posix.1
routine. Both vxWorks and RTEMS just return
osiSpawnDetachedProcessNoSupport so there's no issue there; the other
implementations of osiSpawnDetachedProcess() are for VMS and WIN32,
neither of which call exit().
Another problem though appears to be that at no point does the CA
client library actually fork off a caRepeater itself, even after this
message appears:
CA client library is unable to contact CA repeater after 50 tries.
Silence this message by starting a CA repeater daemon
or by calling ca_pend_event() and or ca_poll() more often.
I'm afraid I don't understand. With caRepeater on the PATH everything works
as expected for me (3.14.9). E.g., the test program I submitted with my
last post succeeds in spawning a repeater and I see it running and listening
on port 5056.
Also, if spawning the caRepeater is successful then I do not get
the 'CA client library is unable to contact CA repeater after 50 tries'
message.
(This I tested with a different CA client - obviously ca_zombie_test.c
is not
suitable for this purpose)
-- T.
I proved that as follows: With caRepeater running, I can find the
following output from netstat (NB: ca-2 is the IANA official name for
our port on recent OS releases; on older releases you may have to use
5065 instead - look in your /etc/services file to see whether you have
ca-1 and ca-2 defined):
uranus% netstat -a | grep 'ca-2'
udp 0 0 *:ca-2 *:*
With cau running as above there is no output from that command. Was
this functionality removed intentionally Jeff?
- Andrew
- Re: CA client on unix bug Andrew Johnson
- CA client on unix bug Till Straumann
Re: EPICS/RTEMS bug in osdPoolStatus.c Till Straumann
<2007>
2025
2026
<2007>
2025
2026
