1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA client on unix bug
To: "'Till Straumann'" <[email protected]>, "'TECHTALK tech-talk'" <[email protected]>
Date: Mon, 11 Jun 2007 14:50:45 -0600
Till,
Completely agree with your assessment of the situation, and your fix. In my
defense, what actually occurs when one calls exit() has been evolving quite
a bit with each new release of R3.14.
Jeff
-----Original Message-----
On Behalf Of Till Straumann
Sent: Sunday, June 10, 2007 1:38 PM
To: TECHTALK tech-talk
Subject: CA client on unix bug
I found the following problem (tested on
linux, solaris, base-3.14.9, base-3.14.8.2)
with the CA client on unix:
Scenario:
IF
  - no caRepeater is running
  - CA client tries to fork a caRepeater
    but the 'exec' syscall fails (e.g., because the
    caRepeater is not found in PATH)
THEN
 the forked process may end up blocking
 for an event that never happens and hence
 may never exit (see attached test program for
 more details) and therefore never release system
 resources.
FIX: libCom/osi/os/posix/osdProcess.c:osiSpawnDetachedProcess()
  should call _exit() rather than exit() if execle() fails.
REPRODUCE: try attached code (comments contain analysis
of the problem).
-- Till
CA client on unix bug Till Straumann
Prev: Re: CA client on unix bug Andrew Johnson
Next: RE: CA client on unix bug Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CA client on unix bug Jeff Hill
Next: GigE Vision-compliant cameras Malitsky, Nikolay D
