1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asynRecord SEGFAULT?
To: Heinrich du Toit <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Tue, 19 Jun 2007 06:35:55 -0500
Perhaps you have a runaway pointer in your code which is overwriting some other part of memory and that causes problems later on.
Can you send your entire driver so we can have a look? If it's lengthy, please send it to me rather than to the entire list.
On Jun 19, 2007, at 5:44 AM, Heinrich du Toit wrote:
Hi
I've started experimenting with asyn.
Now I've created the routines for a driver with Common and devInt32
interfaces.
When I connected my own record (ai) 2 this to read it works fine.
Then I tried connecting a asynRecord to this.
It starts up fine.
But when I run medm to see this record the IOC segfaults.
plockRecord->plockSet
because plockSet = null
and this is because precord->lst = null
And that must be the lockRecord or something.
I don't understand, the stack trace doesn't even run through asyn or my
own code.
I have no idea where to look for the fault :(
-Heinrich
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
asynRecord SEGFAULT? Heinrich du Toit
Prev: asynRecord SEGFAULT? Heinrich du Toit
Next: RE: asynRecord SEGFAULT? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
