1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asynRecord SEGFAULT?
To: Heinrich du Toit <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Tue, 19 Jun 2007 15:42:47 +0200
Hi Heinrich
You must load EVERYTHING before iocInit().
Dirk
Heinrich du Toit wrote:
figured it out!!
The order of command in my st.cmd was wrong.
For some reason I must load asynRecord:
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=A,PORT=port0,ADDR=6,IMAX=0,OMAX=0")
before I call iocInit()
else the lockSets aren't setup correctly.
I don't really understand why this is so?
sorry for the trouble :)
There is just so much about epics I am yet to understand
-Heinrich
On Tue, 2007-06-19 at 12:44 +0200, Heinrich du Toit wrote:
Hi
I've started experimenting with asyn.
Now I've created the routines for a driver with Common and devInt32
interfaces.
When I connected my own record (ai) 2 this to read it works fine.
Then I tried connecting a asynRecord to this.
It starts up fine.
But when I run medm to see this record the IOC segfaults.
plockRecord->plockSet
because plockSet = null
and this is because precord->lst = null
And that must be the lockRecord or something.
I don't understand, the stack trace doesn't even run through asyn or my
own code.
I have no idea where to look for the fault :(
-Heinrich
-- Dr. Dirk Zimoch Computing and Controls Paul Scherrer Institut phone +41 56 310 5182 fax +41 56 310 4413
asynRecord SEGFAULT? Heinrich du Toit
Re: asynRecord SEGFAULT? Heinrich du Toit
Prev: Re: asynRecord SEGFAULT? Heinrich du Toit
Next: another asyn question... Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
