1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn and a 3rd party API?
To: "Bertrand H.J. Biritz" <[email protected]>, <[email protected]>
Date: Thu, 21 Jun 2007 12:11:57 -0500
Hi Bertrand,
You can certainly do this.
You will be writing an "asyn port driver".  You need to decide what asyn
interfaces your driver will implement (asynOctet, asynInt32,
asynUInt32Digital, asynFloat64, etc.).  Unless the device is very
unusual you won't need to write any EPICS device support, you can use
the standard asyn EPICS device support, which will then talk to your
driver.
You then write your driver to implement the interfaces that you have
chosen to support.  For example, if you implement asynFloat64, then your
asynFloat64Read function will call the C function that the vendor
provided to read some double parameter from the device.  You will
probably want to implement asynDrvUser interface to handle the need to
handle multiple parameters for each asyn interface.  Your template file
might look like:
# ai records to read voltage and current
record(ai, "$(P)Current") {
    field(DTYP,"asynFloat64")
    field(INP,"@asynMask($(PORT) $(ADDR))VOLTAGE")
    field(LINR,"LINEAR")
    field(EGUL,"$(EGUL)")
    field(EGUF,"$(EGUF)")
    field(HOPR,"$(EGUF)")
    field(LOPR,"$(EGUL)")
    field(PREC,"$(PREC)")
    field(INP,"@asynMask($(PORT) $(ADDR))CURRENT")
Here are 2 drivers you can look at for examples:
1) The Modbus driver
http://cars.uchicago.edu/software/epics/modbus.html
2) The Canberra AIM MCA driver (source file
mcaApp/CanberraSrc/drvMcaAIMAsyn.c)
http://cars.uchicago.edu/software/epics/mca.html
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Bertrand
> H.J. Biritz
> Sent: Thursday, June 21, 2007 11:52 AM
> To: [email protected]
> Subject: Asyn and a 3rd party API?
> Dear Tech-talk,
> okay, I am pretty lost right now.
> I was hoping to use asyn to use a third party API to
> communicate with
> a power supply. But for the life of me I can't figure out how to do
> this.
> The manufacturer supplied a C library of functions to talk with the
> crate and I would like to have asyn use those functions. Is this
> possible?
> Could someone point me into the right direction of how to do
> this (an
> example code would be the best but I will take whatever I can get :)
> Sincerely,
> Bertrand
Re: Asyn and a 3rd party API? Bertrand H.J. Biritz
Prev: Asyn and a 3rd party API? Bertrand H.J. Biritz
Next: Re: Asyn and a 3rd party API? Bertrand H.J. Biritz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
