1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Basic Question regarding input links
To: [email protected]
Date: Fri, 22 Jun 2007 10:34:09 +0200
On Wednesday 13 June 2007 03:13, Luedeke Andreas wrote:
> Of course you can use PP on input links, too:
> it causes the record that the link points to to process before the data
> is read from the link.
Caveat: the data you get over a PP input link might be stale (i.e. not the
new value but the old one from the last processing) if the record that the
link points to is processed asynchronously. Whether processing is
synchronous or asynchronous is mostly decided by the device support.
Cheers
Ben
RE: Basic Question regarding input links Mark Rivers
Re: Basic Question regarding input links Luedeke Andreas
Prev: Re: Asyn assertion failure (long) Dirk Zimoch
Next: RE: Asyn assertion failure (long) Denison, PN (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Basic Question regarding input links Luedeke Andreas
Next: VxWorks Buffer Problems Matt Rippa
