1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn assertion failure (long)
To: "Denison, PN \(Peter\)" <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Fri, 22 Jun 2007 13:23:16 +0200
Peter,
intrCallbackOctet is used to implement "I/O Intr" scanning.
To get more information (which record are involved, etc), try to enable debugging and direct the debug output to a file:
StreamDebugFile=fopen("filename","w")
streamDebug=1
However, this might give lots of output and the timing might change slightly. I have seen situations, where the bug disappears when debugging is enabled.
Have you seen similar effects on Linux IOCs? I can't test everything on vxWorks here, because of the variety of existing hardware.
Does it happen during startup or later? I can't see any direct relation between autosave and StreamDevice/asyn.
Dirk
Asyn 4-8, streamDevice 2-2, EPICS 3.14.8.2, vxWorks 5.5.1 on MVME5500
What port driver are you using? One of those provided with asyn (serial, TCP, ...) or a third party driver?
We're using the asynSerialPort, on top of a Hytec 8516 RS-485 module in
a Hytec 8002 IP carrier.
About 600 chars: The asynInterposeEos layer uses an internal buffer of 600 chars which it passes to lower level drivers.
As it may also be a bug in StreamDevice, please send me your protocol file and records so that I can try to reproduce your
problem.
Sure. We are trying to cut it down to the minimum to cause it to fail,
and also trying to reproduce on a test system, as the production IOC
will have to roll back to a working version for our next run starting on
Monday.
The crash appears to be in StreamDevice (data is trashed between the
calls to callInterruptUsers() and interruptEnd(), seemingly in the
intrCallbackOctet callback).
However, in trying to isolate it, the behaviour changes when autosave
state changes. We are using autosave 4-2-1, with local modifications to
the names of the status PVs.
Thanks for your help - I'll keep you posted.
-- Dr. Dirk Zimoch Computing and Controls Paul Scherrer Institut phone +41 56 310 5182 fax +41 56 310 4413
RE: Asyn assertion failure (long) Denison, PN (Peter)
Prev: RE: Asyn assertion failure (long) Denison, PN (Peter)
Next: ARCnet on Linux Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Asyn and a 3rd party API? Bertrand H.J. Biritz
