1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asynRecord and Labview problem
To: "Mikel Eguiraun" <[email protected]>, <[email protected]>
Date: Tue, 26 Jun 2007 08:00:41 -0500
I suspect the problem is with Labview, not with asynRecord, since BINP works OK in other applications.
I don't know the Labview interface.  You need to make sure that it is trying to read a char array for BINP, not an EPICS string PV.
From: [email protected] on behalf of Mikel Eguiraun
Sent: Tue 6/26/2007 5:46 AM
To: [email protected]
Subject: asynRecord and Labview problem
hello,
 I have an epics server publishing information from an osciloscope using
asynRecord, and i want to take this information using Labview (8.5b). I
have problem reading BINP field of asynrecord to take the points of the
scope's screen (the rest of the fields are ok),  i get the following
error in Labview:
"Warning -1950679034 occurred at Shared Variable Read in server.vi
Possible reason(s):
LabVIEW:  (Hex 0x8BBB0006) The shared variable has no value.
This warning occurred while reading \\My Computer\server\Variable1
(\\192.168.0.5\server\Variable1)"
but if I use the command shell i am able to take those points. I am new
to epics and labview, so i don't know in which side the problem is, has
anybody have any suggestion to fix this problem?
many thanks in advance
Mikel Eguiraun
Re: asynRecord and Labview problem Mikel Eguiraun
Prev: asynRecord and Labview problem Mikel Eguiraun
Next: Use of modbus tcp driver Touchard Dominique
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: asynRecord and Labview problem Mikel Eguiraun
