1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: medm, edm, other on fc6
To: "Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]" <[email protected]>, "Emmanuel Mayssat" <[email protected]>, <[email protected]>
Date: Wed, 27 Jun 2007 16:21:25 -0500
Title: RE: medm, edm, other on fc6
I was able to get MEDM compiled using
openmotif-devel-2.3.0-0.1.9.3.fc6.ccrma
openmotif-2.3.0-0.1.9.3.fc6.ccrma
This is essentially the same version that Bob Soliday mentioned in a separate e-mail.  I believe that the –devel rpm is needed to compile as this provides the header files but is not needed on a machine that will simply run the compiled code.
I got EDM compiled although it is not fully tested.  I did find that I had to get past some version of EDM to achieve this.  My solution at the time was to grab the latest from the ORNL web page.
John Hammonds
Beamline and Data Acquisition Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]
(630)252-5317
From: [email protected] [mailto:[email protected]] On Behalf Of Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Sent: Wednesday, June 27, 2007 3:46 PM
To: Emmanuel Mayssat; [email protected]
Emamanuel,
     Are you missing openmotif?  Fedora Core 6 removed openmotif, and does not include it.  Fedora Core 5 was supposed to be the last Fedora openmotif.
     I took openmotif from Fedora Core 5 and used "rpm" to install "openmotif-2.3.0-0.1.9.2.i386.rpm" which is all that should be needed.  I also installed "openmotif-devel-2.3.0-0.1.9.2.i386.rpm" although it should not be needed.
     An alternative would be to get openmotif.xxxxx.tar.gz and compile and install it, if your prefer.
Billy R. Adams
757-864-5934
-----Original Message-----
From: [email protected] on behalf of Emmanuel Mayssat
Sent: Wed 06/27/07 4:28 PM
To: [email protected]
Subject: medm, edm, other on fc6
Hello,
I am having a few difficulties compiling medm specifically on fedora
core 6. First I had to install the lesstif-devel to get missing header
files, then I change my CONFIG_SITE.linux-x86.linux86 and customize it
to my platform, then when I compile and I get conflicting definition for
_XmDrawShadow which is declared as extern in /usr/include/Xm/XmDraw.h
and in .../medm/xc/Matrix.c. As a result, Matrix.c doesn't compile.
Bummer! Has anyone experienced this problem?
I tried to compile edm in place of medm.
Again I hit roadblocks on fc6.
I did not investigate the reason in depth.
But is there anything that I can use to visualize me PV on fc6 (i.e.
that is straight forward to compile) ?
I also remember reading a thread related to Motif support in future
linux versions. If I remember correctly motif was not going to be
supported any more. Is that true?
E
medm, edm, other on fc6 Emmanuel Mayssat
RE: medm, edm, other on fc6 Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Prev: Re: medm, edm, other on fc6 Bob Soliday
Next: backward compatibility, machine virtualization, development environment Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: medm, edm, other on fc6 Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Next: Re: medm, edm, other on fc6 Bob Soliday
