1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asyn record support - output
To: TechTalk EPICS <[email protected]>
Date: Fri, 29 Jun 2007 14:37:25 +0200
Hi
I've created an asyn driver that provides a asynInt32 multi_device
interface. Actually the addr is simply different "registers" on the same
device.
Everything works fine - well mostly.
The registers are multi-directional in the driver.
ie. you can write them and you can read them. - Interrupts also works
Offcourse some registers are for reading and other for writing.
Now on one such register for writing I've put a longout record.
As this register will configure the device I want to put in a default
value in the .db file.
so I added the DOL field to the longout register. (this will set the
default VAL of the record and it does)
But when the system initializes the thing goes and READ this register
using the driver. This not only overwrites the default value. It also
gives some garbage as the device can be in unknown state.
I've made a workaround using DrvUser Interface and passing a startup
value that way - but this just doesn't seem like a good solution.
Why does a longout record call the drivers READ command at startup?
Doesn't make sense 2 me.
-Heinrich
RE: asyn record support - output Mark Rivers
Re: asyn record support - output Marty Kraimer
Prev: Re: PV save and restore tool sought Elder Matias
Next: RE: asyn record support - output Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PV save and restore tool sought Eric Norum
