1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Beacon
Cc: TechTalk EPICS <[email protected]>
Date: Thu, 05 Jul 2007 10:57:58 -1000
That's one reason.
Another one is if you have recently moved an IOC onto a different
subnet or to a different IP address. The DNS cache can do weird things
(both on the network/router/DNS server and on the IOC itself) -
I remember seeing similar problems at some point, and you can
probably find that thread in the tech-talk archives searching for
DNS cache.
Aloha,
Maren
Mark Rivers wrote:
I believe those are multicast message, i.e. sent to the broadcast address with with a specific port, in this case 5064. I think I have seen that message when some device on the network is not ignorring the multicast as it should, but is replying with a "Connection refused" message. In our case it was a terminal server that was doing that.
From: [email protected] on behalf of Heinrich du Toit
Sent: Thu 7/5/2007 1:26 AM
To: TechTalk EPICS
Subject: CA Beacon
Hi
We have a local control net.
This is the first time I run an IOC on it:
I get the following message:
../online_notify.c: CA beacon (send to "172.16.255.255:5065") error was
What does this mean? Why is it trying to connect to the broadcast
address?
-Heinrich
CA Beacon Heinrich du Toit
RE: CA Beacon Mark Rivers
Prev: Re: CA Beacon Ralph Lange
Next: trouble with custom record Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CA Beacon Mark Rivers
Next: Re: CA Beacon Ralph Lange
