1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: trouble with custom record
To: Heinrich du Toit <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Fri, 06 Jul 2007 08:23:51 -0500
Heinrich -
There is a built-in <and functional> "template" that gives a complete example (dbd files, Makefile, c-code, st.cmd file) for adding your own custom record. Look at the IOC Application Developer's Guide, Example IOC Application (Section 2.2 in 3.14.9 version).
Specifically, look at the src directory after you perform the two makeBaseApp commands specified in Section 2.2.2.
HTH -
Ned
From: [email protected] on behalf of Heinrich du Toit
Sent: Fri 7/6/2007 3:45 AM
To: TechTalk EPICS
Subject: trouble with custom record
Ok so I read all the stuff on custom records.. And I think I understand
the programming part and how the functions should get called ect ect.
But I can't seem to get the things to compile?
I have myRecord.dbd with record def inside. dbToRecordH thingy works
I have myRecord.c with the code. It can compile fine.
But I can't seem to get this to load into the actual ioc.
When I try to DBLoadDataBase(myRecord.dbd) then it complains about
dbCommon.dbd not available.
If I try to load myRecord.dbd as part of my ioc.dbd with the makefile
the I get some error in ioc_registerRecordDeviceDriver.cpp
if I try to get it to "expand" a new .dbd for my record it complains
about menu stuff missing.
help?
trouble with custom record Heinrich du Toit
RE: trouble with custom record Mark Rivers
Prev: RE: trouble with custom record Mark Rivers
Next: EPICS Web server upgrade tomorrow Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
