1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA Beacon
To: Heinrich du Toit <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Thu, 05 Jul 2007 10:19:44 +0200
Hello Heinrich,
I just had a glance at the relevant documents ("CA Reference Manual" and "CA Protocol Specification" available on the Documents/CA page of the EPICS web site) and had to realize that neither one contains a good entry-level description of the basic CA principles. Another weak point in the not-that-complete EPICS documentation, I would say.
So:
Beacons are UDP broadcast messages (usually on port 5065, if not configured differently) sent periodically by all CA servers (IOCs). They are received by a process called caRepeater residing on every CA client host, that forwards them to all CA client processes on that host.
The client program uses the received beacon messages for two things:
1. As a server "alive" message. If the client doesn't receive a beacon message within some (configurable) time span from a server it is connected to, it will try to verify that server's state by sending ping messages on the data (TCP/5064) connection. If the server doesn't answer these, the client will flag all channels from that server as "disconnected".
2. As a hint when to broadcast name resolution requests. Whenever the client sees a "new" beacon signal (e.g. from a new IOC booting up), it will rebroadcast the name resolution requests for all its unresolved and disconnected channels, as that new IOC might host some of the missing channels.
For more detailed information, try searching for the word "beacon" in the documents mentioned above.
Hope this helps,
Ralph
Heinrich du Toit wrote:
Hi
We have a local control net.
This is the first time I run an IOC on it:
I get the following message:
../online_notify.c: CA beacon (send to "172.16.255.255:5065") error was
"Connection refused"
What does this mean? Why is it trying to connect to the broadcast
address?
-Heinrich
CA Beacon Heinrich du Toit
Prev: CA Beacon Heinrich du Toit
Next: RE: CA Beacon Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
