1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget segment fault
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Mon, 09 Jul 2007 14:25:56 -0500
Make sure the running caRepeater application is from the same epics version as caget. You could be running the 3.14.6 caRepeater when using the other two releases.
For more info on caRepeater see Ralph's email on "beacons" from this morning.
Geoff
On Jul 9, 2007, at 1:54 PM, Emmanuel Mayssat wrote:
Hellom
I am trying to compile epics base 3.14.8.2 and 3.14.9 on redhat 8.0
After compilation, caget <PV> (most of the time) returns a value and
immediately segment fault.
Compilation of 3.14.6 works great.
Any idea what that could be?
Emmanuel
RE: caget segment fault Jeff Hill
caget segment fault Emmanuel Mayssat
Prev: caget segment fault Emmanuel Mayssat
Next: RE: CA Beacon, error messages when sending Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: caget segment fault Jeff Hill
