1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ASLO / AOFF scaling for ai and ao record
To: EPICS tech talk <[email protected]>
Date: Fri, 13 Jul 2007 18:31:20 +0200
Hello all,
I have a device that came with a controller from the vendor. This controller
offers a TCP/IP server you can connect to and send a certain set of commands
to operate the device.
Using EPICS, asyn and streamdevice, it has been close to trivial to set up a
basic softIOC to operate the device (essentially a getPosition/setPosition
operation).
In the streamdevice protocol file I have (among others)
getX {
        out "Joe Crds ?";
        in "Joe Crds %f %*f %*f %*f %*f %*f %*f ";
setX {
        out "Joe AxisAbs 1 %(VAL)f";
        in "Joe started";
In the database I have (among others)
record (ai, "MyIOC:X")
        field (SCAN, ".1 second")
        field (DTYP, "stream")
        field (INP,  "@device.proto getX MYPORT")
	# EGU, HOPR, LOPR, PREC, warning limits, ... left out for brevity
record (ao, "MyIOC:setX")
        field (SCAN, "Passive")
        field (INP,  "@device.proto setX MYPORT")
	# EGU, DRVL, DRVH, PREC, warning limits, ... left out for brevity
This works like a charm, I can do "caget MyIOC:X" to get the current position
and "caput MyIOC:setX <targetpos>" to drive to a target position.
Now I want these records to operate in different, linearly transformed
coordinates rather than in the device's very own coordinates, let's say for
example
myCoords = -20.5 * devCoords + 5.3 .
Therefore, I added
        field (ASLO, "-20.5")
        field (AOFF, "5.3")
to the ai and ao records described above; for the ai record, this had the
desired effect, i.e. the record now delivers the position in transformed
coordinates.
However, the ao record _ignores_ ASLO and AOFF with a streamdevice device
support. Is this the intended behaviour? Or a bug in streamdevice's device
support for the ao record?
How are you supposed to solve the problem of linear coordinate transformations
without adding a bunch of helper records (calc & calcout, or even motor) to
the database?
The LINR="Slope" ESLO/EOFF scaling of the ao record would be sufficient, if
only RVAL was a double rather than a long; atm if you use it, it
truncates "devices coordinates" to whole numbers after doing the correct
transformation.
Any suggestions?
-Stefan
Stefan Heim, PhD Student X-ray microscopy
BESSY mbH, Albert-Einstein-StraÃe 15, D-12489 Berlin, Germany
voice: +49 30 6392 3177 fax: + 49 30 6392 4757 e-mail: [email protected]
BESSY mbH - Mitglied der Leibniz Gemeinschaft
Vorsitzender des Aufsichtsrates: Prof. Dr. Dr. h.c. mult. Joachim Treusch
GeschÃftsfÃhrer: Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Prof. Dr. Eberhard
Jaeschke
Sitz Berlin, AG Charlottenburg, HRB 14635
Re: ASLO / AOFF scaling for ai and ao record Stefan Heim
Re: ASLO / AOFF scaling for ai and ao record Tim Mooney
Prev: Re: Scan question John Faucett
Next: Re: ASLO / AOFF scaling for ai and ao record Stefan Heim
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Scan question Emmanuel Mayssat
