1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: medm with epics-base 3.14.6+
To: epics <[email protected]>
Date: Fri, 20 Jul 2007 13:45:33 -0700
Hello,
I am trying to update my driver to a more recent epics base.
I assume that if I do so, I need to recompile the epics extensions.
The issue I face is with medm 3_1_1 and 3_1_2_1 (the latest version) on
the base R 3.14.9 (and R 3.14.8.2 ).
Medm builds correctly, but when I start and ioc and attach a medm
display to it it immediately freeze.
The behavior I observe is as if the process was sleeping (I can move the
window, but display do not refresh and is blanked when I bring other
gnome widgets on the top of the medm window).
NOte: medm 3_1_1 works correctly on epics base 3.14.6 on same machine
It seems to be an issue with the channel access.
As anybody seen this before?
I am running on linux RH8.0 (default install)
Emmanuel Mayssat
Re: medm with epics-base 3.14.6+ Ralph Lange
Prev: Re: How to declare the command array? Eric Norum
Next: Re: medm with epics-base 3.14.6+ Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
