1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Alternative for National instruments card
To: "Heinrich du Toit" <[email protected]>
Cc: [email protected]
Date: Tue, 24 Jul 2007 14:34:24 +0100
It is true that National Instruments provide a Linux driver for a subset
of their product range. In case you are interested in going down that
route: the driver is called "NI-DAQmx Base" which is a subset of the
functionality in the "NI-DAQmx" driver which does not work on (all?)
Linux systems.
Here is a list of the supported hardware for the NI-DAQmx Base driver:
http://digital.ni.com/softlib.nsf/websearch/FA87D0FA8A3C2085862571E6006A
4D64?opendocument&node=132060_US
Here is a pointer on how to get started with NI-DAQmx Base on Linux:
http://zone.ni.com/devzone/cda/tut/p/id/3838
Apart from the LabVIEW interface to this driver, it also comes with an
ANSI C API which I found surprisingly simple to use once I got the
driver running -you need to run a free (as in beer) LabVIEW runtime
engine and tweak various bits and pieces first...
I only have one piece of NI hardware - the NI-USB-6009 - but since the C
API is (almost) the same for all their hardware I started to write an
ASYN based driver support for NI-DAQmx Base. Eventually it could be a
generic driver across multiple hardware boards... It is a "rainy day"
kind of a project as my boss calls it so it is far from complete any
time soon but if one day we will get enough rain...
Let me know if you are interested in more details or code.
Cheers,
Ulrik
-----Original Message-----
[mailto:[email protected]] On Behalf Of Heinrich du Toit
Sent: 24 July 2007 07:38
To: TechTalk EPICS
Subject: Alternative for National instruments card
Hello
We have a project were we want to monitor some values (some analog some
digital)
This is mostly for archiving and then later reviewing to determine if
equipment is working as it should over longer periods of time.
Also to try and determine if some equipment would need to be replaced
ahead of the time when failure occurs.
So far we've considered the national instruments cards. As they can do
all the I/O we require.
They are also fairly easy to interface using DotNet.
But there is already a channel archiver for EPICS which I think is worth
using maybe?
I know there are some Linux drivers for NI cards. Haven't looked at them
yet.
But maybe there is some other card or system I can consider for this
project?
Thanks for your time
-Heinrich
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
RE: Alternative for National instruments card David Dudley
Alternative for National instruments card Heinrich du Toit
Prev: Nexus charge amplifier support? Shepherd, EL (Emma)
Next: RE: Alternative for National instruments card David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Alternative for National instruments card Ralph Lange
