1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stream/asyn devices
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Fri, 27 Jul 2007 10:07:06 +0200
Emmanuel,
If you can send me the complete web page (or the URL if it is acessible from the web), I can try to build a protocol which works without regexp. It depends on the complexity of the page is that is possible or not.
Dirk
I have a device which has a web server and a simple web page.
My record should fetch the web page and extract the value between the
<epics> and </epics> tags. Can asyn do that? ( it probably can ;)
stream/asyn devices Emmanuel Mayssat
Prev: Re: stream/asyn devices Dirk Zimoch
Next: Re: asyn driver for CMLOG? Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: asyn driver for CMLOG? Heinrich du Toit
