1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn driver for CMLOG?
To: TechTalk EPICS <[email protected]>
Date: Fri, 27 Jul 2007 10:51:40 +0200
Ok that's great, will look into it. :)
But what I need is more like a message log system.
The means like it can log 100 messages in a second if something happens
and then sit quite for 3 days.
That's why I was thinking to use the stringout record. Then my SNL
program can simply write to the stringout record and that will get
logged everytime. Or maybe this is not such a good idea?
On Thu, 2007-07-26 at 22:29 -1000, Maren Purves wrote:
> don't know about CMLOG, but in the channel archiver you just
> set the record to monitor.
> How often you log or archive things ought to be set up in
> the logger/archiver. It shouldn't have anything to do with
> how a record processes (at face value. Of course if you monitor
> a record it will).
> We still have almost brute force cau cron jobs running that just
> log and plot (don't try this on a network that has a B300 on it
> unless you're really sure about your network masking and such -
> of course nobody but us has B300s)
> Aloha,
> Maren
> On Fri, 27 Jul 2007, Heinrich du Toit wrote:
> > Hi
> > I guess CMLOG is the logging system of choice? Or is there something
> > else I should look at?
> > Anyways I was wondering If there is somewhere some sort of device
> > support (maybe asyn) so that you can maybe link a stringout record to
> > the logger or something like that.
> > I guess most common thing you want is to have a seq program to output to
> > the logger? How should I do this?
> > Thankyou
> > -Heinrich
Re: asyn driver for CMLOG? Luedeke Andreas
Re: asyn driver for CMLOG? Maren Purves
asyn driver for CMLOG? Heinrich du Toit
Prev: Re: asyn driver for CMLOG? Maren Purves
Next: Re: asyn driver for CMLOG? Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
