1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: VxWorks time()
To: "Kevin M. Peterson" <[email protected]>, "tech-talk" <[email protected]>
Date: Tue, 31 Jul 2007 11:46:13 -0500
Kevin,
I doubt if this is your problem.  However, looking at the Linux documentation for ctime() I see that:
       The four functions acstime(), ctime(), gmtime() and localtime()  return
       a  pointer  to  static data and hence are not thread-safe.  Thread-safe
       versions acstime_r(), ctime_r(), gmtime_r() and localtime_r() are spec-
       ified by SUSv2, and available since libc 5.2.5.
So ctime is not thread-safe.  I would suggest that you consider converting from time() and ctime() to the epicsTimeGetCurrent  and epicsTimeToStrftime() functions from libCom.
From: [email protected] on behalf of Kevin M. Peterson
Sent: Tue 7/31/2007 11:28 AM
To: tech-talk
Subject: VxWorks time()
After upgrading an ioc from:
Processor: MVME2700
BSP: mv2700-asd8_nodns
EPICS version: R3.13.9
synApps version: 4-6
to:
Processor: MVME5100
BSP: mv5100-asd8_nodns
EPICS version: R3.14.8.2
synApps version: 5_2_test
a sequence program that writes the current date and time
into a file no longer logs the correct time.
The time on the ioc is correct:
lga> date
2007/07/31 11:14:56.572507
value = 27 = 0x1b
lga>
but the method used by the sequence program which worked
before the upgrade, no longer behaves properly:
lga> systime = time(0)
systime = 0x1e1a8d10: value = 423436 = 0x6760c
lga> printf("%s",ctime(&systime))
MON JAN 05 15:37:16 1970
value = 25 = 0x19
lga>
Originally I thought that something might have changed in the
sequencer but since I see the same incorrect behavior on the
VxWorks console I'm forced to look elsewhere for the problem.
The VxWorks documentation says time() should return the current
time if passed NULL (which the sequence program does).  Is time()
broken in mv5100-asd_nodns?  If not, where else can I look for a
potential misconfiguration?
Thanks ahead of time,
Kevin
VxWorks time() Kevin M. Peterson
Prev: VxWorks time() Kevin M. Peterson
Next: RE: VxWorks time() Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
