Note that there's always been stuff in base to do the time sync:
In 3.14, the code in src/libCom/osi/os/vxWorks/iocClock.c will create a
thread that does a regular NTP sync with the server specified by the
environment var EPICS_TS_NTP_INET (default: boot server). Watch for a
thread named "syncNTP".
In 3.13, drvTS was part of base, so calling "TSconfigure" with no
arguments from the startup script (making the IOC a "soft timing slave")
would have the IOC do a regular NTP sync with the server specified by
the same environment var (default: boot server). Set "TSdriverDebug=10"
on the vxWorks shell to see what it's doing.
The main purpose of generalTime is to allow for multiple time sources to
be configured, with the IOC switching between the sources on
availability to always automatically provide the most accurate time
possible.
Cheers,
Ralph
Thompson, David H. wrote:
The time(0) will return the number of seconds that the IOC has been
running unless you set it. Unless the ioc has been up for a year ctime
would convert that into a date in 1970 since time(0) is 1/1/70 00:00
GMT.
Out kernels make a call to sntpTimeGet() and then a call to
clock_settime() before running the startup script. That gets it right
for a while but it will drift. You can make these calls from the top of
the startup script so long as you malloc a block of memory to hold a
struct timespec to pass to the two calls.
The generalTime driver may do the same thing.
- Re: VxWorks time() Andrew Johnson
- VxWorks time() Kevin M. Peterson
- RE: VxWorks time() Thompson, David H.
Re: PV save and restore tool sought (correction) Carl Lionberger
edm: bug-reports unnecessary? Ralph Lange
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
