1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: "build" make target now installs
To: [email protected]
Date: Mon, 13 Aug 2007 12:42:34 -0400
In the 3.13 Makefile system, "make build" would do compilation, build
libraries, expand dbd files, etc, etc, but would not "install" anything.
This allowed testing of new code or build options without having to use a
separate build tree to avoid interference with production software.
Under 3.14, I find that "make build" only prevents installation of
"products", ie. executable host programs and IOC applications.  It does not
prevent the installation of dbd files, libraries or header files.
I note that "build" is not listed in section 4.5.2 (Frequently used Make
commands) of the AppDevGuide, appearing only in the fine print of section
4.5.3 (Make targets).
Do only "Frequently used" targets actually get tested for proper behavior ?
Brian McAllister                                   Senior Software Engineer
[email protected]                      Bates Research & Engineering Center
(617) 253-9537                                                Middleton, MA
Re: "build" make target now installs Tim Mooney
Prev: Re: breaktable checks in dbLexRoutines.c in 3.14.9 Andrew Johnson
Next: Re: "build" make target now installs Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
