On Aug 14, 2007, at 06:59 , Heinrich du Toit wrote: Hi Hi: From past EPICS training sessions it's become obvious to me that this is one of the most confusing things about EPICS. The IOC database has Records. A Record has Fields: The analog input record "fred" has fields VAL, EGU, TIME, HOPR, LOPR, STAT, SEVR, ... You use the database file or later at runtime the dbgf and dbpf commands to deal with fields of a record. Over the network protocol, ChannelAccess, you access Channels. A Channel has Properties: A Channel "fred" has properties value, time stamp, units, upper display limit, status, severity, ... You use the DBR_... request types to read/write the properties of a channel (called "database request types" DBR_..., should be "channel" or "property" request types) How do Records map to Channels, how do Fields of a Record map to the Properties of a Channel? To really know, you have to use the force and read the source. The result makes sense in the few but most common cases. It doesn't make sense in most of the other possible cases. The one example that makes perfect sense: You have a channel "fred" for an AI record "fred", and ask for a DBR_CTRL_DOUBLE. Your channel will provide the following properties in a dbr_ctrl_double structure, mapped to the following fields of the record: value = VAL status = STAT severity = SEVR precision = PREC units = EGU upper_disp_limit = HOPR lower_disp_limit = LOPR upper_alarm_limit = HIHI ... You can also ask for a DBR_TIME_DOUBLE and get the value = VAL stamp = TIME ... The time stamp is of course the time of the last value update, so it's the time stamp that belongs to the value. This case makes perfect sense. The next good example is a channel "fred.SCAN", which is of type ENUM and you can get the DBR_CTRL_ENUM properties: value = SCAN strs = { "Passive", "Event", ..., ".1 second" } Good, that's the current value as well as coresponding enumeration strings. But there's also status = STAT severity = SEVR Those are status & severity of the VAL field. A "NO_ALARM"/"NO_ALARM" or "READ"/"INVALID" in there doesn't say anything about the SCAN field. Now attach a channel to "fred.HOPR" and read the DBR_TIME_DOUBLE: value = HOPR stamp = TIME You get a time stamp that has nothing to do with the value. It's not the time when HOPR was last updated. Attach a channel to "fred.HOPR" and read a DBR_CTRL_DOUBLE: value = HOPR units = EGU status = STAT severity = SEVR lower_ctrl_limit=-32768 upper_ctrl_limit=32767 value and units are OK. But status & severity again apply to the VAL of the record, not the HOPR field. The control limits are simply the range of the 16 bit number that's in the PREC field. Is a negative PREC of any use? So if your channel name is simply a record name, the mapping of record fields to channel properties makes sense. In other cases, you have to look at the source code of the record to figure out what you'll get, and in many cases it's questionable. You also have to understand that ChannelAccess cannot introspect the record (iterate over the fields). There's no DBR_ALL_FIELDS, only a fixed set of DBR_... requests with a hardcoded mapping to fields inside each record's code. -Kay
| ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
