You should use the devLib functions in EPICS base. devRegisterAddress and devReadProbe. If you use those functions your code should be portable to other operating systems like vxWorks.
Sent: Mon 8/13/2007 9:40 PM
To: [email protected]
Subject: RTEMS access VME bus
now I'm trying to access the vme bus with RTEMS. first I translate a
known VME address into a CPU address with BSP_vme2local_adrs(unsigned
address_modifier, unsigned long vmeaddr, unsigned long *plocaladdr), and
then I want to test whether the board exists with a function, e.g.
rtmsDevWriteProbe or rtmsDevReadProbe, but I can't find the two functions in
RTEMS4.6.0, any function to test? thanks!
Haoli Shi
- RTEMS access VME bus 师昊礼
RE: dm2k not compiling :( guobao shen
RE: dm2k not compiling :( Hammonds, John P.
<2007>
2025
2026
dm2k not compiling :( Heinrich du Toit
<2007>
2025
2026
