1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: bug fixes for R3.14.8.2
To: Geoff Savage <[email protected]>
Cc: epics <[email protected]>
Date: Wed, 15 Aug 2007 10:02:16 -0500
Hi Geoff,
Geoff Savage wrote:
How do I determine which patches I need for R3.14.8.2? 1. Look in the known problems for R3.14.8.2 and apply the patches there.
Yup, and also check the later Known Problems pages just in case. The patches mentioned may not all be necessary depending on what features you actually use, but I to try and keep the Known Problems list *for the latest release* up to date with all of the essential bug fixes that apply to that release. If you're using an older release there may be issues described in the newer Known Problems pages so you should look at them too â the applicability of a patch is usually discussed when the problem it fixes is known to exist in earlier versions too.
2. How do I determine which Mantis entries apply to this base release?
Andrew Johnson gave a talk at DESY which seemed to say that mantis entries 282 and 288 are essential.
I was talking about R3.14.9 when I mentioned those particular entries, they do not apply to R3.14.8.2 (#282 specifically says so, and I'm fairly sure this is true of #288 as well since Jeff had been working in that area for the 3.14.9 release). You can look for particular entries that mention 3.14.8.2 using the search facility on the Mantis "View Bugs" page; make sure you have the "Hide Closed" check-box un-checked. This won't necessarily tell you that later entries don't also apply too though; unfortunately that's not an easy problem to solve without making extra work for the already stretched maintainers, but that's why I try to keep that information in the Known Problems pages.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
bug fixes for R3.14.8.2 Geoff Savage
Prev: Re: SDDS? Anthony F. Pietryla
Next: Re: SDDS? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: bug fixes for R3.14.8.2 Geoff Savage
Next: SDDS? Heinrich du Toit
