1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: breakpoint table bug R3.14.8
To: tech_talk <[email protected]>
Date: Wed, 15 Aug 2007 13:43:02 -0700
The breakpoint table bug, which I reported last year (see tech-talk thread starting: Fri, 12 May 2006) is back in R3.14.8.2. Maybe it was never fixed? We are still running mostly R3.13.10, where I had implemented my own fix locally. Now we installed a Linux based IOC and our Silicon Diode breakpoint conversions screw up again.
(Just to save you looking up the thread: If you have a table, where the raw values are increasing and the engineering values are decreasing, the algorithm as implemented doesn't work correctly).
- rolf -
| Rolf Keitel, Ph.D., TRIUMF        Tel: (604) 222-7453 |
| Manager Electronics and Controls  Fax: (604) 222-7307 |
| Engineering Division                                  |
| Vancouver, B.C., Canada                               |
Re: breakpoint table bug R3.14.8 Andrew Johnson
Prev: Re: SDDS? Andrew Johnson
Next: Re: breakpoint table bug R3.14.8 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
