1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ArchiveDataTool converting from freq_directory
To: <[email protected]>
Date: Wed, 22 Aug 2007 11:52:40 +0100
Hi
I am using the ArchiveDataTool to convert old freq_directory files into
new indices for the Channel Archiver. I get an assertion on some
directories, I suspect due to non-monotonic timestamps. Has anyone had
similar problems / found a solution?
Thanks
James
Software Engineer
Diamond Light Source
ArchiveDataTool -dir2index ./BR02C/VA/IOC-01/freq_directory
./BR02C/VA/IOC-01/new_master_index
08/21/2007 09:03:36
ASSERT 'start <= end' FAILED:
../RTree.cpp (697)
This is a timestamp ASSERT:
// Insertion follows Guttman except as indicated
RTree::YNE RTree::insertDatablock(const epicsTime &start,
                                  const epicsTime &end,
                                  FileOffset data_offset,
                                  const stdString &data_filename)
    stdString txt1, txt2;
    YNE       yne;
    int       i, additions;
    Datablock block, new_block;
    Node      node(M, true);
    LOG_ASSERT(start <= end); // (RTree.cpp line 697)
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
Prev: RE: asyn - interrupts Heinrich du Toit
Next: RE: asyn - interrupts Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: asyn - interrupts Mark Rivers
Next: asyn 4.8 problem Robert Emery
