1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data
To: Peter Zumbruch <[email protected]>
Cc: [email protected]
Date: Wed, 22 Aug 2007 15:02:41 -0500
Hi Peter,
Peter Zumbruch wrote:
- The file "$EPICS-BASE/src/libCom/osi/default/osdWireFormat.h"
has been extended by those two lines to comply for the little-endianness :
    #elif defined (_cris_)
    #     define EPICS_LITTLE_ENDIAN
Are you sure that this architecture is little-endian? It looks to me from your results below like you should try using EPICS_BIG_ENDIAN. Here's why:
DBR_STRING      3
DBR_SHORT       768
DBR_LONG        50331648
and what it should look like:
DBR_STRING      3
DBR_SHORT       3
DBR_LONG        3
If I convert the short result 768 to hex, the result is 0x0300 instead of 0x0003, i.e. the high and low bytes of the 16 bit result have been swapped from what they should contain. Similarly converting the long result to hex gives 0x03000000 which implies the wrong endianness.
Try making that change in osdWireFormat.h and recompiling and I suspect this problem will disappear.
Once this is resolved I'll be happy to add this new architecture to the next official release.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Peter Zumbruch
Prev: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Peter Zumbruch
Next: RE: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
