1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: alpha NI drivers
To: Tech-Talk EPICS <[email protected]>
Date: Fri, 24 Aug 2007 08:40:17 +0200
Hi all
I made a post awhile ago asking about NI drivers. Then Ulrik Pederson
from DIAMOND responded and said he had some code.
I then started to continue development on this driver and have made much
progress since then.
I recently asked about eagle drivers as they have similiar cards.
Emmanuel Mayssat said he is interested in the NI driver. So I thought
that maybe somebody else is also interested.
So Here is some information:
The SVN repos:
http://epics.svn.sourceforge.net/viewvc/epics/applications/trunk/DAQmxBase/
(use "svn co addr" to checkout)
You won't have upload/commit permissions.
Inside the source under the documentation folder is the current
documentation. See readme first.
The driver uses NI's DAQmxBase drivers at this stage.
http://zone.ni.com/devzone/cda/tut/p/id/3838
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14480
download iso here:
http://digital.ni.com/softlib.nsf/websearch/FA87D0FA8A3C2085862571E6006A4D64?opendocument&node=132060_US
download run-time engine here:
http://joule.ni.com/nidu/cds/view/p/id/702/lang/en
USE AT OWN RISK :)
Actually I don't think this is the best driver to be using as it only
supports a few linux distro's. Will maybe consider using something else
later on.
-Heinrich
Prev: Programmers position in Australia LYNCH, Damien
Next: COMEDI EPICS driver support? Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
