1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV name changes and epics extensions
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Fri, 24 Aug 2007 14:08:39 -0500
Emmanuel
This is one of the features of the IRMIS relational database.
IRMIS consists of, in part, all of the PVs in your system. A pv crawler (a perl program) detects when an IOC reboots, then scans and expands that IOC's st.cmd file to load the IRMIS database with that IOCs PVs. This scanning is unobtrusive to the IOC.
Other crawlers have been written to scan CA clients. At the APS, we crawl for MEDM, ALH, and SDDS clients, and we are testing the SNL crawler written at SLAC. We intend to crawl save/restore files as well (future). For each CA client instance, a list of resolved PVs is generated, and inserted into the IRMIS database.
Taking the MEDM client as an example, the crawler resolves the macro substitutions for nested MEDM screens, so that it tells you which .adl file in the chain needs to be fixed if a given PV is removed.
Crawlers for other CA clients have been written at other facilities - EDM, DM/2K for example.
Don Dohan
Emmanuel Mayssat wrote:
Another question about software upgrade...
Let's say that I change the name of PV in my epics database.
Potentially with this change, I could break epics extensions.
Medm of course, but also feedback system, PV backup, etc.
Is there a way to know which extensions will break if I change a PV
name? (may keeping track for each extension of the used PVs in a flat
file is the solution, but is there any other, smarter ones?)
Emmanuel
Re: PV name changes and epics extensions Emmanuel Mayssat
Prev: RE: Network plug and play epics devices David DeBonis
Next: Re: PV name changes and epics extensions Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: PV name changes and epics extensions Emmanuel Mayssat
Next: Re: PV name changes and epics extensions Emmanuel Mayssat
