1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data
To: Peter Zumbruch <[email protected]>, Jeff Hill <[email protected]>
Cc: [email protected]
Date: Mon, 27 Aug 2007 16:02:56 +0200
Hi Peter, Jeff,
I had the same problem with little endian Embedded Linux targets, Axis and others. I wanted the problem solved once and for all without having to modify the base source code for every new target.
I used 3.14.8, which handles endianess a bit different.
In ca/net_convert.h, I modified the code from
... (known targets)
#else
#       define CA_FLOAT_IEEE
#       define CA_BIG_ENDIAN
#endif
to
#else
#if  !(defined(CA_FLOAT_MIT) || defined(CA_FLOAT_IEEE) )
#endif
#if !(defined(CA_LITTLE_ENDIAN) || defined(CA_BIG_ENDIAN) )
#endif
#endif
This allows to define endianess in my CONFIG.Common.linux-crisv10 file instead of the source code:
ARCH_DEP_CPPFLAGS += -DCA_LITTLE_ENDIAN
In my opinion, the config files are a much better place to configure the system than the source code.
The same could be done for 3.14.9 in libCom/osi/os/default/osdWireFormat.h where we can already read:
// Perhaps the definition of EPICS_BIG_ENDIAN, EPICS_LITTLE_ENDIAN,
// and EPICS_32107654_FP_ENDIAN should be left to the build system
// so that this file need not be modified when adding support for a
// new architecture?
Modify the code to:
... (known targets)
#elif !(defined (EPICS_BIG_ENDIAN) || defined (EPICS_LITTLE_ENDIAN) )
#	define EPICS_BIG_ENDIAN
#endif
Dirk
Peter Zumbruch wrote:
Hello everybody,
I am working on the port of EPICS to ETRAX CRIS architecture running Linux.
We are using several boards which either have Axis's chips:
   ETRAX LX100 MCM (cris_v10)
       (http://www.axis.com/techsup/dev/etrax_100lx_mcm/index.htm)
       or    ETRAX FS (cris_v32)
as a control unit on-board.
I meanwhile have succeeded ( :-) ) in compiling EPICS 3.14.9 on a linux-x86 host-system for those two architectures:
- The CONFIG files needed to be create are documented at:
linux-cris_10:
http://wiki.gsi.de/Epics/ConfigurationEpicsCrossCompileLinuxCrisV10
linux-cris_32:
http://wiki.gsi.de/Epics/ConfigurationEpicsCrossCompileLinuxCrisV32
where exclusively linux-cris files have been modified/created.
   - Changes in CONFIG_SITE.linux-x86.Common:
       CROSS_COMPILER_TARGET_ARCHS = linux-cris_v10 linux-cris_v32
- The cross-compiler used is a gnu-compiler provided by axis:
cris-gcc --version: cris-axis-elf-gcc (GCC) 3.2.1 Axis release R64/1.64
- The file "$EPICS-BASE/src/libCom/osi/default/osdWireFormat.h"
has been extended by those two lines to comply for the little-endianness :
    #elif defined (_cris_)
    #     define EPICS_LITTLE_ENDIAN
- The optimization -O3 had to be replaced by -Os or the default -O0 to be able to compile.
Also the example Application created via
   |$EPICS_BASE/bin/linux-x86/makeBaseApp.pl
|compiles ||meanwhile without problems.
Copied to the target system (cris_v10 Target) the IOC starts up thoroughly.
"dbl, dbpr, etc" applied to all given records seem to work.
But,
pardon me for the long introduction,
(either locally or remotely) looking with a client application to the the values the data are corrupted:
using *camonitor* gives for aiExample2
   (normally having a counter running  from 0 to  9):
zumbruchHost:aiExample2 2007-08-22 20:08:32.843735 4.33197e-320 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:08:34.853797 0 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:08:36.864724 3.03865e-319 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:08:38.873781 3.16202e-322 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:08:40.883986 1.04347e-320 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:08:42.894597 2.05531e-320 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:08:44.903989 2.56124e-320
zumbruchHost:aiExample2 1904-10-15 19:11:38.551617 3.06716e-320 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:08:48.924495 3.57308e-320 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:08:50.933987 4.07901e-320 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:08:52.944423 4.33197e-320 ?? ??
zumbruchHost:aiExample2 1909-01-16 05:53:46.278750 0 ?? ??
zumbruchHost:aiExample2 1910-02-08 14:34:18.543753 3.03865e-319 ?? ??
zumbruchHost:aiExample2 1911-03-03 23:14:50.955094 3.16202e-322 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:09:00.984164 1.04347e-320 ?? ??
zumbruchHost:aiExample2 1913-04-18 16:35:54.407488 2.05531e-320 ?? ??
zumbruchHost:aiExample2 1914-05-12 01:16:26.675635 2.56124e-320
zumbruchHost:aiExample2 2007-08-22 20:09:07.014232 3.06716e-320 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:09:09.024221 3.57308e-320 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:09:11.034747 4.07901e-320 ?? ??
zumbruchHost:aiExample2 2007-08-22 20:09:13.044186 4.33197e-320 ?? ??
zumbruchHost:aiExample2 1919-09-04 20:39:06.413164 0 ?? ??
for comparison a similar well running application ("What it should look like")
zumbruch2Host:aiExample2       2007-08-22 20:08:32.613470 1 LOLO MAJOR
zumbruch2Host:aiExample2       2007-08-22 20:08:34.615208 2 LOLO MAJOR
zumbruch2Host:aiExample2       2007-08-22 20:08:36.617301 3 LOW MINOR
zumbruch2Host:aiExample2       2007-08-22 20:08:38.618697 4 LOW MINOR
zumbruch2Host:aiExample2       2007-08-22 20:08:40.620584 5
zumbruch2Host:aiExample2       2007-08-22 20:08:42.622103 6 HIGH MINOR
zumbruch2Host:aiExample2       2007-08-22 20:08:44.623496 7 HIGH MINOR
zumbruch2Host:aiExample2       2007-08-22 20:08:46.624957 8 HIHI MAJOR
zumbruch2Host:aiExample2       2007-08-22 20:08:48.627479 9 HIHI MAJOR
zumbruch2Host:aiExample2       2007-08-22 20:08:50.629924 0 LOLO MAJOR
zumbruch2Host:aiExample2       2007-08-22 20:08:52.631170 1 LOLO MAJOR
The same for *ca_test*:
native type: DBR_DOUBLE
native count: 1
DBR_STRING 3
DBR_SHORT 768
DBR_FLOAT 0.0000
DBR_ENUM 768
DBR_CHAR 3
DBR_LONG 50331648
DBR_DOUBLE 0.0000
DBR_STS_STRING 1536 256 Value: 3
DBR_STS_SHORT 1536 256 Value: 768
DBR_STS_FLOAT 1536 256 Value: 0.0000
DBR_STS_ENUM 1536 256 Value: 768
DBR_STS_CHAR 1536 256 Value: 3
DBR_STS_LONG 1536 256 Value: 50331648
DBR_STS_DOUBLE 1536 256 Value: 0.0000
DBR_TIME_STRING 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 3
DBR_TIME_SHORT 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 768
DBR_TIME_FLOAT 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 0.0000
DBR_TIME_ENUM 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 768
DBR_TIME_CHAR 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 3
DBR_TIME_LONG 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 50331648
DBR_TIME_DOUBLE 1536 256 TimeStamp: 1901/12/13 21:45:52.547135 Value: 0.0000
DBR_GR_STRING 1536 256 Value: 3
DBR_GR_SHORT 1536 256 Counts
2560 0 2048 1536 1024 512 Value: 768
DBR_GR_FLOAT 1536 256 Counts 0
0.000 0.000 0.000 0.000 0.000 0.000 Value: 0.0000
DBR_GR_ENUM 1536 256 Value: 768
DBR_GR_CHAR 1536 256 Counts
10 0 8 6 4 2 Value: 3
DBR_GR_LONG 1536 256 Counts
167772160 0 134217728 100663296 67108864 33554432 Value: 50331648
DBR_GR_DOUBLE 1536 256 Counts 0
DBR_CTRL_STRING 1536 256 Value: 3
DBR_CTRL_SHORT 1536 256 Counts
2560 0 2048 1536 1024 512 2560 0 Value: 768
DBR_CTRL_FLOAT 1536 256 Counts 0
0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 Value: 0.0000
DBR_CTRL_ENUM 1536 256 Value: 768
DBR_CTRL_CHAR 1536 256 Counts
10 0 8 6 4 2 10 0 Value: 3
DBR_CTRL_LONG 1536 256 Counts
167772160 0 134217728 100663296 67108864 33554432 167772160 0 Value: 50331648
DBR_CTRL_DOUBLE 1536 256 Counts 0
0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 Value: 0.000000
DBR_STSACK_STRING 1536 256 256 512 3
DBR_CLASS_NAME ai
and what it should look like:
native count: 1
DBR_STRING 3
DBR_SHORT 3
DBR_FLOAT 3.0000
DBR_ENUM 3
DBR_CHAR 3
DBR_LONG 3
DBR_DOUBLE 3.0000
DBR_STS_STRING 6 1 Value: 3
DBR_STS_SHORT 6 1 Value: 3
DBR_STS_FLOAT 6 1 Value: 3.0000
DBR_STS_ENUM 6 1 Value: 3
DBR_STS_CHAR 6 1 Value: 3
DBR_STS_LONG 6 1 Value: 3
DBR_STS_DOUBLE 6 1 Value: 3.0000
DBR_TIME_STRING 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3
DBR_TIME_SHORT 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3
DBR_TIME_FLOAT 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3.0000
DBR_TIME_ENUM 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3
DBR_TIME_CHAR 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3
DBR_TIME_LONG 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3
DBR_TIME_DOUBLE 6 1 TimeStamp: 2007/08/22 20:15:16.962527 Value: 3.0000
DBR_GR_STRING 6 1 Value: 3
DBR_GR_SHORT 6 1 Counts
DBR_GR_FLOAT 6 1 Counts 0
10.000 0.000 8.000 6.000 4.000 2.000 Value: 3.0000
DBR_GR_ENUM 6 1 Value: 3
DBR_GR_CHAR 6 1 Counts
DBR_GR_LONG 6 1 Counts
DBR_GR_DOUBLE 6 1 Counts 0
DBR_CTRL_STRING 6 1 Value: 3
DBR_CTRL_SHORT 6 1 Counts
DBR_CTRL_FLOAT 6 1 Counts 0
10.000 0.000 8.000 6.000 4.000 2.000 10.000 0.000 Value: 3.0000
DBR_CTRL_ENUM 6 1 Value: 3
DBR_CTRL_CHAR 6 1 Counts
DBR_CTRL_LONG 6 1 Counts
DBR_CTRL_DOUBLE 6 1 Counts 0
10.000 0.000 8.000 6.000 4.000 2.000 10.000 0.000 Value: 3.000000
DBR_STSACK_STRING 6 1 1 2 3
DBR_CLASS_NAME ai
Could somebody give me an advice where else to look at?
Thanks in advance,
Peter
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Andrew Johnson
RE: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Jeff Hill
Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Peter Zumbruch
Prev: Re: TDS3012B scope Benjamin Franksen
Next: RE: bug in Red Hat Linux g++ 3.2.3 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Peter Zumbruch
Next: Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Andrew Johnson
