1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Alarm Handler
To: Umashankar Panda <[email protected]>
Cc: [email protected]
Date: Mon, 27 Aug 2007 10:53:31 -0500
The releases alh1_2_23 and medm3_1_2_1 have R3.14 Makefiles and use definitions from files in
the extensions/configure directory. You probably need to correct the X11 and MOTIF definitions
in the extensions/configure/os/CONFIG_SITE.linux-x86.linux-x86 file on the machine giving error
messages.
The older medm releases medm3_0_3Beta2 and medm3_0_3 have R3.13 type Makefiles and use the
X11 and MOTIF definitions from the extensions/config directory.
Janet
Umashankar Panda wrote:
Dear Sirs,
I am new to tech-talk.
I have installed Red Hat Enterprise Linux 4 in two machines. In one machine
I am able to make the alarm handler alh1_2_23 and medm3_1_2_1 where as
in the other one I receive the following errors where as the
installation in both the machines are identical.
I have checked that openmotif runtime and developement are installed
in both the machine. However medm3_0_3Beta2 and medm3_0_3 are not
giving any error and running fine.
Alam Handler Error:
make[1]: *** No rule to make target `/local2/X11R6/lib/libXmu.a',
needed by `alh'.  Stop.
make[1]: Leaving directory `/epics/extensions/src/alh1_2_23/O.linux-x86'
make: *** [install.linux-x86] Error 2
Medm Error:
ake[2]: *** No rule to make target `/local2/X11R6/lib/libXm.a', needed
by `medm'.  Stop.
make[2]: Leaving directory `/epics/extensions/src/medm3_1_2_1/medm/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/epics/extensions/src/medm3_1_2_1/medm'
make: *** [medm.install] Error 2
Please help !!!
With regards
Alarm Handler Umashankar Panda
Prev: Re: PV name changes and epics extensions Don Dohan
Next: RE: PV name changes and epics extensions Rock, Judith E.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Alarm Handler Umashankar Panda
Next: ASYN & ioclog/CMLOG Heinrich du Toit
