On Monday 27 August 2007 23:58, Szalata, Zenon M. wrote:
> In the above, the GPIB number is 0, the instrument primary GPIB address
> is 10 and its secondary address is 0.
> I do not know how to make a connection between the NI4882 driver and the
> test application.
You need to place a 'driver configuration' call in your startup file
somewhere before the call to iocInit. Take a look at the asynDriver manual
(http://www.aps.anl.gov/epics/modules/soft/asyn/R4-8/asynDriver.html),
especially the section called "port drivers" and there (presumably)
subsection "Linux-Gpib". You should find documentation on which routine to
call and which parameters to give.
Cheers
Ben
"Prevention is better than cure, in particular if the illness is unmastered
complexity, for which no cure exists." [E.W.Dijkstra]
- Soft IOC for A GPIB Instrument Szalata, Zenon M.
Re: Soft IOC for A GPIB Instrument Emmanuel Mayssat
<2007>
2025
2026
<2007>
2025
2026
