1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: sscan record and StreamDevice positioners
To: EPICS tech talk <[email protected]>
Date: Fri, 31 Aug 2007 02:54:44 +0200
sorry for the following lengthy expose to a problem regarding completion
notification.
I have several positioners (multiple axes devices) controlled via several
get/set pairs of ai/ao records per axis with a StreamDevice device support
(DTYP=streams).
Sometimes, the underlying "hardware" protocol offers only a set method without
completion notification for a given axis. The StreamDevice protocol file
section then has s.th. like
> setX {
>         out "AxisAbs 1 %f";
>         in "AxisAbs 1 movement_started";
Here the device emits the "AxisAbs 1 movement_started" as mere confirmation of
the control order. There is no further reply indicating completion of the
positioning operation.
While moving, the position can be monitored in an event based manner, i.e.
a .SCAN="I/O Intr" ai record
| record (ai, "$(IOCNAME):stage:$(AXIS)")
|         field (SCAN, "I/O Intr")
|         field (DTYP, "stream")
|         field (INP,  "@protocol_file.proto get$(AXIS) PORT")
based on a protocol
> getX {
>         @init {
>                 out "registerVC 2 IOC:stage:X Joe";
>                 in "Joe Crds %f %*f %*f %*f %*f %*f %*f ";
Here, the device's capability to do registration based position monitoring is
gluelessly linked with EPICS' monitor concept. The out command issued during
init causes the device to send position update messages ("Joe Crds ...") as
if you posted a monitor on one (or several) EPICS process variable(s).
The six floats thrown away in the "in" part of this protocol ("%*f") are
typically read by a further set of (six) .SCAN="I/O Intr" ai records,
offering completely seperated control information and linear rescaling of the
raw values by means of the respective .ASLO and .AOFF fields. With the
same .ASLo/.AOFF rescaling applied to the corresponding ao record of a given
axis, this rescaling is transparent to the user/client.
In addition, there is a state variable ("ready") available with the same
subscription based event notification mechanism,
| record (bi, "$(IOCNAME):stage:ready")
|         field (INP,  "@protocol_file.proto getReady PORT")
|         field (ZNAM,  "not ready")
|         field (ONAM,  "ready")
with protocol
> getReady {
>         @init {
>                 out "registerVC 32 IOC:stage:ready Joe";
>                 in "Joe %{not ready|ready}";
Now if I want to use the sscan record to operate on these positioners, it
expects them to do be capable of ca_put_callback()-based completion
notification. However, e.g. travelling from 0.0 to 10.0 takes ~13 s
| sheim@txm1:~$ camonitor TXM1CL:micos:ready TXM1CL:micos:ZCOARSE &
| [1] 7781
! TXM1CL:micos:ready             2007-08-31 02:09:33.733498 ready
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:11.154559 0 LOLO MAJOR
| sheim@txm1:~$ caput -c TXM1CL:micos:setZCOARSE 10
| Old : TXM1CL:micos:setZCOARSE        0
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:44.735909 0.022526
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:44.757608 0.039484
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:44.779335 0.061448
! TXM1CL:micos:ready             2007-08-31 02:09:44.800247 not ready
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:44.803464 0.087914
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:44.828070 0.120282
| New : TXM1CL:micos:setZCOARSE        10
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:44.849671 0.164518
| sheim@txm1:~$
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:44.870746 0.205295
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:44.891945 0.251714
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:44.914267 0.303483
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:44.935013 0.36009
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:45.658592 4.99687
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:45.680585 5.21379
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:45.703397 5.42912
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:46.587214 9.98588
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:46.609446 9.99538
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:46.631317 9.99971
! TXM1CL:micos:ZCOARSE           2007-08-31 02:09:46.653736 10
! TXM1CL:micos:ready             2007-08-31 02:09:47.107716 ready
but the caput -c above returns "immediately". Furtermore, the device is
possibly late to give out the "not ready" notification (cf. trace above), but
guarantees to fire "ready" only after (all) movements finished.
While I read the slides on completion notification in Scans.ppt and tried to
understand the busy record, I still wonder what might be the best approach to
the problem. Essentially, I need a way to use StreamDevice based devices not
offering a synchronous setPosition command as positioners with the sscan
record.
Any clues?
-Stefan
Stefan Heim, PhD Student X-ray microscopy
BESSY mbH, Albert-Einstein-Straße 15, D-12489 Berlin, Germany
voice: +49 30 6392 3177 fax: + 49 30 6392 4757 e-mail: [email protected]
BESSY mbH - Mitglied der Leibniz Gemeinschaft
Vorsitzender des Aufsichtsrates: Prof. Dr. Dr. h.c. mult. Joachim Treusch
Geschäftsführer: Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Prof. Dr. Eberhard
Jaeschke
Sitz Berlin, AG Charlottenburg, HRB 14635
Re: sscan record and StreamDevice positioners Tim Mooney
Prev: Allen-Bradley Flex IO Ethernet Driver Luchini, Kristi
Next: Re: sscan record and StreamDevice positioners Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
