Thank you Gasper. Your suggestion worked and allowed me to go to the next build problem of the asyn package. Now I get the following errors, which unfortunately look to me like some gcc improper use, or something like that. I am building asyn with linux-gpib on RHEL4 (2.6.9-55.0.2.EL) desktop using gcc-3.4.6-8 and below is some of the output generated:
/usr/bin/g++ -o test -Wl,-Bstatic -L/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/4-3/lib/linux-x86/ -L/afs/sl
ac/package/epics/R3.14.6/base/lib/linux-x86/ -Wl,-rpath,/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/
4-3/lib/linux-x86 -Wl,-rpath,/afs/slac/package/epics/R3.14.6/base/lib/linux-x86 test_registerRecordDeviceDriver.o te
stMain.o -ltestSupport -lasyn -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryI
oc -ldbStaticIoc -lca -lCom -Wl,-Bdynamic -lpthread -lreadline -lcurses -lm -lrt
/afs/slac/package/epics/R3.14.6/base/lib/linux-x86//libdbIoc.a(dbChannelIO.o)(.text+0x4c3): In function `dbChannelIO::write
(epicsGuard<epicsMutex>&, unsigned int, unsigned long, void const*)':
: undefined reference to `std::__default_alloc_template<true, 0>::deallocate(void*, unsigned int)'
/afs/slac/package/epics/R3.14.6/base/lib/linux-x86//libdbIoc.a(dbChannelIO.o)(.text+0x531): In function `dbChannelIO::write
/afs/slac/package/epics/R3.14.6/base/lib/linux-x86//libdbIoc.a(dbChannelIO.o)(.text+0x9d1): In function `dbChannelIO::opera
tor new(unsigned int)':
/afs/slac/package/epics/R3.14.6/base/lib/linux-x86//libdbIoc.a(dbChannelIO.o)(.text+0xa13): In function `dbChannelIO::opera
/afs/slac/package/epics/R3.14.6/base/lib/linux-x86//libdbIoc.a(dbChannelIO.o)(.gnu.linkonce.t._ZNSs12_S_constructIPKcEEPcT_
S3_RKSaIcESt20forward_iterator_tag+0x36): In function `char* std::basic_string<char, std::char_traits<char>, std::allocator
<char> >::_S_construct<char const*>(char const*, char const*, std::allocator<char> const&, std::forward_iterator_tag)':
: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_Rep::_S_create(unsigned
int, std::allocator<char> const&)'
S3_RKSaIcESt20forward_iterator_tag+0x86): In function `char* std::basic_string<char, std::char_traits<char>, std::allocator
: undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_S_empty_rep_storage'
/afs/slac/package/epics/R3.14.6/base/lib/linux-x86//libdbIoc.a(dbSubscriptionIO.o)(.text+0x539): In function `dbSubscriptio
nIO::operator new(unsigned int)':
/afs/slac/package/epics/R3.14.6/base/lib/linux-x86//libdbIoc.a(dbSubscriptionIO.o)(.text+0x57b): In function `dbSubscriptio
/afs/slac/package/epics/R3.14.6/base/lib/linux-x86//libdbIoc.a(dbPutNotifyBlocker.o)(.text+0x8c1): In function `dbPutNotify
Blocker::operator new(unsigned int)':
/afs/slac/package/epics/R3.14.6/base/lib/linux-x86//libdbIoc.a(dbPutNotifyBlocker.o)(.text+0x903): In function `dbPutNotify
/afs/slac/package/epics/R3.14.6/base/lib/linux-x86//libca.a(ca_client_context.o)(.text+0x30c7): In function `ca_client_cont
ext::installDefaultService(cacService&)':
/afs/slac/package/epics/R3.14.6/base/lib/linux-x86//libca.a(ca_client_context.o)(.text+0x3112): more undefined references t
o `std::__default_alloc_template<true, 0>::deallocate(void*, unsigned int)' follow
collect2: ld returned 1 exit status
gmake[3]: *** [test] Error 1
gmake[3]: Leaving directory `/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/4-3/testApp/src/O.linux-x86'
gmake[2]: *** [install.linux-x86] Error 2
gmake[2]: Leaving directory `/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/4-3/testApp/src'
gmake[1]: *** [src.install] Error 2
gmake[1]: Leaving directory `/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/4-3/testApp'
gmake: *** [testApp.install] Error 2
It has been painfull building both linux-gpib and now asyn. Documentation seems incomplete or at least unclear to me. Again any help will be appreciated.
Zen
Building asyn Szalata, Zenon M.
CAC-TCP-recv suspended Shepherd, EL (Emma)
<2007>
2025
2026
<2007>
2025
2026
