1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Python??
To: [email protected]
Date: Wed, 05 Sep 2007 09:44:24 -0400
On 9/5/07 1:57 AM, Heinrich du Toit wrote:
Hi
My question is simply.
Which one?
Hi, Heinrich.
"No. There is another." :-)
I use EpicsCA, written by Matthew Newville:
http://cars9.uchicago.edu/~newville/Epics/Python/
It has worked quite well for me and has good documentation.
-lewis
On the web-site there are 2 different CaPython links. One from FNAL and one from KEK.
I've downloaded KEK so far. Mainly because of the multi-threaded claim.
It seems to do the basics cleanly and easily. I even manage to setup a
monitor fairly easy.
But I can't seem to find documentation on this.
Most of the other info is about the one from FNAL.
I don't know much about this. Accept that it has 2 parts caPython and caChannel.
So which one do I use?
Which one is supposedly newer?
Which one is more widely used by other people?
Any specific pro's cons about them?
And if KEK's - where do I find documenation? The documentation inside
the library doesn't really tell you what todo and the samples is way to
big to figure out what is going on.
-- J. Lewis Muir Software Engineer CARS/IMCA-CAT
Re: EPICS Python?? Matthieu Bec
EPICS Python?? Heinrich du Toit
Prev: cmlog compile problems Heinrich du Toit
Next: Re: CAC-TCP-recv suspended Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Python?? Heinrich du Toit
Next: Re: EPICS Python?? Matthieu Bec
